Loading G7 and G8 Characters coming into Daz Studio with other parameters dialed in.
Just recently whenever I bring in a preset character (any character, bought from DAZ, etc.).   Other parameters are already dialed in from the character.
This problem just started recently and can't imagine anything new I've done with my computer.  Attached is a image of the parameters dialed in.
I've uninstalled DAZ Studio 4.10 pro and all the essentials.  It still does the same thing when reinstalled what I've uninstalled.
Any suggestions as to why this is happening?
Thank you.
Jimmire
  • LeanaLeana Posts: 12,822
    Does it do that when you load the default figure too? If so, it likely means that some morphs have been saved with a non-zero default value (either by you or in a character you installed recently).
  • That usually means a character was saved with non-zero default values - if you click the gear icon on one of those sliders I think you will its default and raw values are still 0, if you click on the Controllers tab at the bottom of the dialogue ne of those is likely to be the culprit.
  • No I didn't save the characters, these are characters from DAZ.  They use to work perfectly now they are coming with morphs values already selected.  Same values appear on all the default characters.
  • fastbike1fastbike1 Posts: 4,079
    The software doesn't change values on its own. Its easy to select save rather than save as.
  • dragotxdragotx Posts: 1,147
    It's probably a character you installed then.  I've had it happen with one I purchased from Renderosity and one from Daz themselves.  Both were fixed very soon after I reported the problem.
    I wasn't saying you saved, I meant the content creator (when saving the Morph Asset).
