Problems with Gumdrops: Kalidah's Forest Playset
Misselthwaite
in The Commons
Has anyone else had this problem - the playset 'loads'... but there's nothing there. The objects won't load, even if imported. Should I just uninstall and reinstall? The other sets seem fine, but of course this is the one I wanted to use ;-P
Same here, but the ojb imports fine, though without textures. I think the textures work in Poser only, the ReadMe talks about the material room. You can apply colors to the material zones in DS though.
Please submit a ticket. https://www.daz3d.com/help/help-contact-us
I have submitted a ticket; but it isn't that they are showing up untextured, they just aren't showing up. I have retextured, checked opacity, and even over-scaled them in case they are minute. I have looked 360 along all axis to see if they appeared there - nothing. Importing the base model also gives nothing.
What do you mean by base model?
Base model: not the Daz file, but the actual geometry...
Daz Help says it's not meant for Daz, only Poser and offered me a refund... but now I had a head-desk moment and loaded the OBJ instead of the CR2 and found it; incredibly tiny, but visible! Yay! I'm so happy I don't mind feeling like an idiot... that kind of week.
If you import the obj then just select "From: Poser" in the import dialog, then it will be normal size and match the gumdrop figures.
