Domino HD for G3 & G8 Load errors
After installing Domino HD for G8 get the following errors (see attached), does not appear to effect G3.  Domino G8 is not the only model effected, as other G8 figures have the same issue.  Removing the Domino product resolves the error.
Looking at the log file (attached) see the following:
2019-01-09 08:14:54.199 WARNING: fileinput\dzassetdaz.cpp(5970): Duplicate formula found linking xOrigin & Value in /data/DAZ 3D/Genesis 8/Female/Morphs/Lyoness/LY_Briallen/FHM_LY_Briallen.dsf.
Looking in my folders at this time for the conflict but as I have had this error before and had to remove and eyelash fie.
Any help IDing the file would be appreatated.
  • fastbike1fastbike1 Posts: 4,083
    I get the same error messages. Looks like an update will be needed. I suggest entering a problem ticket.
  • I would suspect that's a copy-paste from the Briallen when setting up - QA wouldn't have caught it as they test on clean installs (toa void the opposite issue, unexpected dependencies on other products). Please report the issue to Technical Support as a possible bug https://www.daz3d.com/help/help-contact-us
  • TraceSLTraceSL Posts: 547
    Have opened a ticket, I know it is a simple locate and remove the duplicate to resolve.
    edited January 2019
    Richard, I'm not sure I understand your copy-paste comment. I get the error about not finding Simone HD eyelashes when I try to load one of the Domino HD figures. No copy/paste involved. I don't get odd morphs or similar errors on any other G8F characters. I have submitted a ticket.
    Post edited by fastbike1 on
  • Just tried to load the character. Had the same errors.
  • Sorry, I noticed the Duplicate Formulas and missed the texture issue - though again, that looks like using a preset from a different character and not fully updating it. Do the lashes actually look wrong? Sometiems the texture is referenced in the asset file but not actually used.
  • Shawn68Shawn68 Posts: 40
    I just tried this character and had the same result. Is it something to do with the texture file name? I checked the texture folder and found no Simone, but I did find Domino and it has the lashes listed as Domino, not Simone.
  • I would think it's this Simone https://www.daz3d.com/simone-hd-for-genesis-8-female and that it's a result of not updating a file reference.
  • wsgentrywsgentry Posts: 573
    I just used eyelashes from another character. :)
    Scott
    DAZ Support responded to my ticket: it is on the bug tracker for resolution. IME, Lyoness is prompt with these rare occurences.
    Maybe but I do not own that product.
    Which would be why the texture wasn't found - if you did own it the map would be there and would be used, though it may not be the map intended (assuming I am right about the nature of the problem).
  • LyonessLyoness Posts: 1,641
    edited January 2019
    yes, you are right Richard. That is exactly what happened.  a file did not get updated.
    Post edited by Lyoness on
  • Did we ever solve this error? Daz still reports "runtime/textures/lyoness/simone/ly_simone_lashes_1006.jpg" error upon loading the HD figure.
  • SaulCsSaulCs Posts: 67
    edited May 2019
    After installing the Domino HD i started receiving the Duplicate formula error for any G8 figure too.
    Any fix for this problem yet?
    Post edited by SaulCs on
  • zischzisch Posts: 3
    Add me to the list. Everything was fine before installing Domino HD. Must have to do with the Genesis 8 version. Genesis 3 figures load without errors.Only Genesis 8 figures show errors after installing Domino HD. Furthermore the facemorphs of the G8 version show strange results, looks partialy distorted or exaggerated. Any help on this besides uninstalling
  • Richard HaseltineRichard Haseltine Posts: 111,459
    If adding a character set caues the Duplicate Formulas error then yes, it will affect the base figure and all characters using it - that is the expected behaviour.
    edited May 2019
    I got an email that my issue was resolved (I have downloaded the Domino update). However, I am still getting the Duplicate formula messages (WARNING: fileinput\dzassetdaz.cpp(5970): Duplicate formula found linking xOrigin & Value in /data/DAZ 3D/Genesis 8/Female/Morphs/Lyoness/LY_Briallen/FHM_LY_Briallen.dsf.)
    When Domino is installed, not only to I get the duplicate files, buy Domino loads looking like Briallen in my case.
    So, not so fixed.
    Yes, but if that errors are obviously caused by a product I have bought at Daz, than the developer should deliver updates that solve these errors. Otherwise I have paid money for a non working product, that furthermore affects all my G8 figures if installed. Very frustrating
  • nightwolf1982nightwolf1982 Posts: 1,321
    This error is being caused because One of the Domino HD characters - Thora - is sharing a morph name with LY Briallen (the morph name is LY_XXX if I'm recalling correctly).  The fix is to edit the dsf files for Domino_Thora and LY Briallen and replace all instances of LY_XXX with the correct id/name  For Thora, it was FHM_LY_Domino_T in the fhm file, CTRL_LY_Thora_Domino in the ctrl file.  For Briallen, CTRL_LY_Briallen for the ctrl file, FBM_LY_Briallen for the fbm file, FHM_LY_Briallen for the fhm file, JCM_LY_Briallen_LForearmBend_75 for the L jcm file, JCM_LY_Briallen_RForearmBend_75 forthe r jcm file, PHM_LY_Briallen_ears for the phm file.
    All of that cleared up the duplicate formulas issues I encountered between these two products.
    @nightwolf1982
    Why would one need to edit the files for Briallen? When Domino is disabled, Briallen seems to load and look fine (although I not used Briallen extensively)?
    I would have thought editing Domino as you specify would be sufficient.
    Editing both can prevent future issues with duplicate formulas.
    a Domino update has recently gone out.
    Editing a file that isn't officially edited is likely to break presets, and will be overwritten by a reinstall or update.
    edited May 2019
    I still get duplicate formula errors for Briallen after the recent update. Also, loading Domino - Thora results in calling Briallen and Alexandra FHMs. Neither of these products are listed as required. Note that when Domino is disabled, I don't get the duplicate formula errors. I did download and install the recent Domino update.
    I also don't think Thora is supposed to look like Alexandra. Below is the base load for Thora G8F followed by Thora G3F. This is significantly different from the Maeve G8f load, or the Thora G3F load.
    I conclude that the recent update didn't correct all issues. Please note that loading Thora G3F does not produce any duplicate formula errors while both of the Domino G8F loads give the errors.
    txt
    txt
    Domin-Thora-Error.txt
    3K
    663 x 790 - 224K
    720 x 776 - 215K
    Not editing the files can cause issues with morphs functioning properly, if at all.  No offense to Lyoness, I'm sure she'll do her best by her customers, but waiting for an "official" fix for issues like this often means there is never a fix.
    Updates have gone out.  This problem should now be completely resolved
    Hi Lyoness,
    I purchased the Domino product awhile back but I'm seeing some issues with it that I can't seem to resolve with a reinstall of the product. When I load up Either Domino or Thora GF8, no G8 clothing loads properly onto her. It seems to think I've actually loaded the G3 version and autofit gets confused and says it's not a supported product. Strange things seem to happen and I often can't load other products onto her such as makeup, etc. And clothing that I am able to get onto her doesn't act like normal (things like I can't unparent things like hats from her and move them independently within the scene.
    Is this a problem others have encountered? Should I submit a support ticket? I love her and often want to use her, but she's become such an issue that lately I can only just use her morph shapes.
    Cheri Lasota said:
    Hi Lyoness,
    Please submit a ticket.
