Ann by Addy and Genesis question
Knight22179
Over at Rendrosiity, there is a character named Ann by Addy. This is what she looks like. http://cheyenne75.deviantart.com/art/MY-ID-complete-337722871
If anyone has the Ann character, could you please do me a favor and try and transfer the morph through GenX and see if it will go over to Genesis please? I ask this because not all morphs will transfer and I don't want to buy a product that can't be used with Genesis. I'd greatly appreciate any help. :)
Sorry, I don't have her, but I"m glad I looked. That character is gorgeous with a Holliday Grainger/Emily Browning look to her. I added her to my wishlist.
Love your new Avatar, Vaskania. ;)
She is very pretty. Just wish someone had her and could transfer her to Genesis. :)
Thanks. :) Ippo put out an enemy for my gal up at DA too, except his is green and black. lol
I'm debating if I want to go ahead and buy this girl now, or not. I use V4 inside of Poser also, so I wouldn't really be losing anything, but I'm unsure since there are some other things I've had on my wishlist longer that I'd rather grab if I was going to spend atm (I've been waiting for a Parrotdolphin sale, and now there is).
/edit
Give me till about the 9th if nobody else can answer you by then. That's when PD's sale ends and I'm hoping a coupon comes out over the weekend that I can stack with it. If no coupon comes out, I'll pull the trigger on what I want from PD and the character regardless.
Is that you cheyenne75?? lol
I have her, if you give me a little time or two ... I can transfer her over and do a quick render.
^Nice. If you can, can you do it as a side by side? I plan on using her w/ V4, but I'm just curious.
Is this some kind of trap?
*wary danger eyes*
It's always a trap...
... except when it's not.
Well, I'm getting the dreaded "no morph transfer" error at the moment for Ann.
I know there is a way around it.
But I forget what it is. :)
I'm not Cheyyene75, no. And thanks. :)
Nuts. And I know there is a way around it as well. Something about loading V4, injecting the morph, saving as OBJ then import OBJ into Genesis. But I forgot some crucial information because if the morph forces Genesis to always load the morph automatically instead of Genesis default, I forgot how to fix that problem. I know I Have to use EditPadLite, though. :-(
Be careful, it is still often a trap, you merely think it is not!
I have her, here is a quick render of her on genesis....
Oooooo, thank you! She looks fantastic! And you transferred her straight through GenX right? No need for a work-around?
Yes, please do tell!
I could not get her to work the standard way.
sorry, it was a crazy weekend, didn't get a chance to post back...
well, i don't really know any "work-arounds", haha, so i have to say i just used the normal method of transferring morphs -- though it was quite a while ago, and i don't really remember if i had to fiddle with it at all. i have all addy's characters, and some are custom morphs, while a few older ones are dial spins, but all of them have transferred.
the one thing about ann is that her eyes don't line up properly, however, i just use the eye fix that came with her poser file, and it works fine.
i will have a look over my notes for gen x in case i did use a work-around without realizing it!
Thanks, Jade Monkey! :)
okay, i went back to attempt to transfer the morphs again, and realized that i had followed a bit of a work-around!
this is what i did:
loaded up V4, injected Ann's head, (this time with the eye fix, which i originally forgot to add) then brought up the GenX window
In the GenX window, I loaded the V4 cr2, then clicked on the apply pose button, choosing the Ann Head Inj from the pose folder.
At first, this doesn't do anything -- that is it loads up the Ann head under the BODY section as a community morph, but the value stays at zero, so if you just try to transfer right away, you get an error message saying no morphs have any values....
so i clicked on the ann community morph and changed the value to 1...
Then at the bottom i used 'create single morph' and from the select button, 'transfer on for all non-zero morphs'
then i hit the transfer button, and the save dialog came up, let it save it to the default location, etc...
then i loaded up genesis, and clicked through to find the saved head morph. i always go through and reorganize my saved morphs, so i'm not sure where it might be hiding initially -- actor/female/realworld, something like that, i think....
i hope this makes sense! let me know if you need more help, i'll do my best!
Thanks, Jade Monkey! I'll buy Ann and try your way. If I need help, I'll reply here. :)
you're welcome! i've always asked for help on these forums, but i've never been able to return the favor before, haha! let me know if you run into any problems!
