DIM Three times up-date about same product, but still remain bug
kitakoredaz
I do not know who really work to remove meta-data bug of products.
I had already send bug reports about pw surface 2,
It is meta-data simple mistake.
just annoying to set all files again.
but I have done three times before.
I know there are already same report from other user.
they set different installed file location and meta-data. dsx
the actual path is
/Shaders/psSurface2_DS4/pwSurface 2 Resources/
then the dsx set Asset path
then DAZ usually few months later,
up-date the same product. whitout mention where they correct .
and DAZ keep same mistake again and again.
Today, DAZ seems up-date this product, and release new DIM zip again.
but I can not believe,,,
It still keep same mistake, so that no file can be seen as product meta-data still.
even though there are meta-data for product.
So that I believe, even though I report bug reports how many times,
and DAZ up-date product , there is no meaning.
about those whom who do not understand what they need
and not try to remove problem siriously.
and not really read what was reported from user.
then it remove my correct product meta-data again.
what meaning of up-date? just feel bad user?
who can make same mistake three times about same products?
simply do you really try your best?
to keep such terrible work,, hide all bug reports ?
I believe,, usuall company never make same mistake tirtd times
about same products.
The asset path in the dsx is actually the correct one. Just rename the psSurface2_DS4 folder name to read pwSurface2_DS4 instead and you won't have to mess with the metadata. The folder name is wrong, not the metadata.
you seems not understand what is problem.
I have already three times, to correct the dsx files as you said.
I reported as you said.before. I know what I need.
the problem is, why DAZ remain bug, even though they up-date products pacakge.
then you say,, not mistake about meta-data.
No! DSX FILE IS FOR META DATA TOO
if user need to manually correct them, it means meta-data is wrong.
so that there were alerady reports about products. not only from me.
then DAZ auto DIM simply remove my corrected dsx
There is no meaning, which daz mistake about location or meta-data.
there seems no difference.
Maybe I am missing something.
From your initial post (my bold):
I understand the bug is still there, and that's frustrating. All I'm saying is instead of digging through the metadata, just change the folder name in Windows Explorer.
The asset path that's set in the dsx file is what the folder name should be. After all, the product name is pwSurface, not psSurface. If you change the folder name, the metadata should work right because it's looking for it in pwSurface_DS4.
We need not make feel bad each other,, sorry if my atttude was bad manner.^^;
it is simply daz foolish mistake.
why I angry is, daz often keep same mistake, even though they up-date.
they do not check them correctly.
I have many case, which I reported, daz say, now remove bug, and finish the report.
then it cause another problem, or simply remain bug,
(they may change something, but I do not know, there is no meaning
if it still remain bug which I have reported,,)
as for me, I simply do not hope to change directory name if I keep using DIM.
it can not remove or uninstall product.
so that I change dsx with text editor.
if I change directory of product, I need to memorize which product I change directory.
you can expect,, daz may try to version up after few months later or next year,
when I perfectly forget, then suddenly daz version up same product.
then stiil remain bug about many case.
If I install product, it can not overwrite the product . and I can not uninstall product by DIM.
if I need to memorize each exception, I feel better use manuall Installer.
It is same about meta-data , there are many many exception still,
so that user can not rely on smart content .
if rely smart content, there are many exception which daz forget.
(not only old product, I know some product duf dsf still set wrong meta-data, or wrong directory,
so that these items never can be seen in smart contents,
and user may forget perfectly about the product)
