How Does One Choose a Windows PC Computer ?
Adding to Cart…
© 2025 Daz Productions Inc. All Rights Reserved.You currently have no notifications.
Jeez, which country do you live in? In the UK we have standards suppliers have to conform to; they even seem to do a decent job of doing it. (With the exception of the trains - they suck.)
To expand on the PSU theme, a good one is certainly valuable - so too is surge protection - including the phone line; a lightning strike took out my system via the phone line; many years ago, I've had said protection since.
Would you believe, the United States? Most civilized countries bury the electrical grid with the exception of high-voltage power lines. Most of the time they do that here, or they do nowadays. A fair part of the grid over here is old infrastructure on poles-- which means power outages and associated spikes are more common in inclement weather.
Damn! But every country has its issues, and I expect burying all those cables will cost time and money so will take time.
You buy over 1200, and build a system that draws that much, and you will trip breakers. While a wall outlet is rated at 15 amps and 100 volts, therefore 1500 watts, components degrade over time and assuming you can safely hit 1500 is foolish.
no idea where you think found a 1080ti but there are none on Newegg or Amazon at costs that do not make the 2080ti a better option. Pcpartpicker also doesn't know of any.
Intel? Really? You are telling people to spend hundreds of dollars more for at best marginal performance gains? A render box doesn't need that sort of performance. Get Ryzen.
Power supply rated for spikes? WTF? You get a good power strip or if you live somewhere where the power is really bad a UPS. Beyond that the only rating on a psu is the 80+ cert. which has nothing to do with ripple.
Apple stopped building Mac's with Nvidia graphics cards at least 5 years ago. The ones that do exist are only just barely able to render in iray. Most people doing iray renders on Mac's are doing cpu only.
or using external GPU boxes.
And can we please try to have a hardware thread that remains civil?
I guess. Paying hundreds of dollars on top of the cost of the graphic card just strikes me as a bad idea. For that sort of money you could pick up a cheap refurbished PC and put the graphic card in that. Plus I've seen claims that Apple is ending support for Nvidia drivers in the newest version of the MacOS.
I am one of those people that live in an area of "dirty" power and have lost a TV and a monitor to it already. Better to spend a bit more and better safe than sorry. I'm also in the US and rural also...
Laurie
I also agree that 800 to 850 should be fine. The newer Nvidia cards actually draw less power than their former counterparts anyway ;)
FWIW, I render on a USED workstation that I paid less than a thousand dollars for....2 Xeon 8 core processors, 64 gigs of ram, 850 watt power supply. I tossed a new graphics card in it and away I went. Has been working well ever since.
Laurie
I am extremely reluctant to recommend used hardware. If you know what you're looking for and get reasonably lucky you can get a good result. But you could just as easily be out hundreds of dollars.
I do render iRay on my MAC, without an NVIDIA card. But it takes a LOOOOOOOOOONG time, and it can't handle too much content in the scene.
What's a GPU box? I can render on a MAC with a GPU box?
I understand the passion/hositility people express when it comes to what works for them - it is exactly the same kind of emotion that comes up when vocalists discuss the "best" technique for singing. I've come to realize that what one person understands, may be impossible for someone else to understand, and what works for one, may not work for another. Different ways of doing something my be equally "good".
I am handicaped, because with a MAC, the ony decision I have ever had to make was which credit card to use.
The trick is to find a reputable dealer and certified refurbisher. I've had this computer for 3 years and have been running it hard and it's been like a champ.
Laurie
In the USA, after decades of infrastructure neglect, we've had transformers blow up nationwide in high rent places like NYC and remote but no longer so cheap either places like both my mom's and my cousin's yards, or at least the right of way cutting through their land. Transformer blowups tend to easily fry electronic devices even with fused power strips made for electronics and in buildings with modern fuse breakers. There is not really much you can do except unplug such sensitive devices when not in use. My mom and my cousin didn't unplug their electronic and despite fused power strips and modern fuse breaker boxes every electronic device plugged in at the time of transformer blow up was fried.
It's a unit that connects to the system via a cable (I forget which connector is used - Thunderbolt?) and into which you can plug a GPU. I'm not sure how easy they are to use, and as kenshaw011267 says driver support may be an issue, but some people do use them (and indded, use them on Windows boxes to get even more GPUs).
Thunderbolt 3 for the Razer X. The boxes have mostly been marketed as a way to add a gpu to a laptop without one. On Windows they're pretty easy from what I've seen. No idea about using them on a Mac.
These claims are true it seems
https://www.forbes.com/sites/marcochiappetta/2018/12/11/apple-turns-its-back-on-customers-and-nvidia-with-macos-mojave/#533b045737e9
I was an exclusive Mac user for 20 years in the Print industry as Graphic Designer..
I now have two PC's (and my older Mac for Adobe CS and Final cut pro editing)
If indeed GPU rendering is the undeniable future that it seems to be,
then anyone involved in 3D rendering will be better served with windows PC
in terms of both hardware and driver support.
Driver support is THE issue.
If you "upgrade" to OSX "Mojave",only two aging
“Mac Edition” discrete NVIDIA GPUs, the Quadro K5000 and GeForce GTX 680, are officially supported.
Apple continues to make business decisions that make no sense.
Producing machines with few if any user upgradable parts at the price points Apple is selling hardware at is baffling. Who is really going to spend $8k on a machine with no upgrade path at all?
$8k per box is getting into the low end of the datacenter world and if I tried to convince my bosses to buy a box with no upgrade options they'd laugh at me.
I'm not saying you're wrong; I'm saying we need to give the OP options and information; a few people saying their old machine is 'fine' is not useful information; it isn't a large enough data sample to garner information from. It is interesting, and it is something the OP could elect to make a decission on, but they need to know all the info - not just what has been filtered by us.
The same affluent consumers of Luxury brands that pay $1000
USD for an IPhone.
There is ethicly nothing wrong with strategically postioning your product line in the market
as luxury brand if you can succesfully do so.
The OP of this thread and any other buyer of consumer level CG rendering hardware
just needs to understand the technical reasons why Apple/Mac OS is no longer a good choice for this endeavour.
There is a similar thread right now, in the C4D forum over at CGsociety,
Most longtime Die hard Mac fanbois have accepted reality ... move to
Windows PC's for their GPU based 3D/CG production or be left behind.
It seems that Apple have a elected to market their products as luxury items that have phone/computer functionality; this is as an alternative as marketting it as a luxury computer or phone item. It is a luxury item first, that is its raison d'être.
LIke I said originally: Huge amouts of money for "pretty". With MacOS ending driver support for nVidia, that's one more reason NOT to get a Mac if you want to do any real work that isn't Excel.
As for some of the other information out there, I wouldn't recommend an external video card either, even on Thunderbolt 3. You're looking at some nasty bottlenecks compared to a card that's on the physical bus. Same goes for most anything else. External hard drives, same thing (says the guy that's using more than one of them). CPU and RAM is another potential bottleneck issue, so take care.
As for me, I'm currently on a 1060 with 6GB, and whilst it doesn't render innstantly, it's a whole lot better than what's in the laptop I was using before.
I am the OP. I never considered a MAC computer a luxury brand. I bought them because they each lasted between 8-10 years without ever having to be upgraded in any way, and never had to be serviced, and almost never crashed or froze. I have been using the same 27inch iMac for 9 years, and considering I paid less than $3000 for it, that works out to about $300 a year. I am an artist, and not interested in tech stuff. (although I DO consider the iPhone and the Apple Watch as luxury goods, and a waste of money). I would absolutely buy another new MAC if it was not for iRay. I resent the fact I have to pay thousands of dollars extra now just to render a DAZ scene, and I have certainly even considered just abandoning DAZ instead.
I have no idea what sort of artist you are but I've built PC's for digital artists who could no longer afford Mac's and for their associates who saw their new machines and were impressed by the performance and price.
The fact is that even when taking into account the premium I charge to spec, order and build a computer the PC's I build are still cheaper for superior performance compared to any Mac on the market. The only component I cannot procure at a reasonable price that is found on Mac's is the 5k display. But there are plenty of great 4k displays.
To me, and a lot of others, that certainly makes Mac's seem like a luxury brand.
I found this site that makes it look like you can now use NVIDIA cards with new MACs. I don't understand what they're talking about, but it looks promising. https://9to5mac.com/2018/05/05/nvidia-egpu-thunderbolt-macos-script-video/
you don't need to spend thousands though
it can be done for under a thousand stick to an adequate power supply for now, everything is replaceable down the track,
just get 16GB of RAM, or even just 8 in a pinch if more slots are available for upgrade and leave yourself open to upgraging to 32 if desired in the future, while 8 not much it will get you off to a start until you can add more.
Honestly if an i5 mobo is dirt cheap 16 is all it can use but I'd strongly advise getting i7 as multithreaded and better for other programs like Carrara, you get twice the render tiles as your cores, mine 4core I get 8
the graphics card the main thing for iray, get a nice one
get a shop to build it for you, many that do postal orders will do bespoke builds too.
The new CEO of Apple has stated that Apple products are being repositioned as a luxury brand although anybody on a budget or that needed their electronics to be top of the line capable or at least upgradable to top of the line computationally knows that that spiel was just veiled language hinting that the already expensive luxury Apple products are going to be made even more expensive. Why? I imagine because they were already so expensive that the average consumer couldn't afford the yearly or bi-yearly upgrade cycle costs already anyway so Apple may as well discourage those that couldn't afford that completely out of the market and offset the revenue losses in higher prices with folk that can really afford that.
