All New Worldbase XT Lushlands
I purchased the ALL NEW WORLDBASE XT LUSHLANDS awhile ago, but had not used it recently. Now I cannot make it work correctly. Among other problems I cannot load the "skies" into the scene. Does anyone know where I can find instructions for this product? Thanks.
You load the Full item. To change the SKY you use the Scene Tab Expand the item and Select the SKY section then apply the new Sky texture. It works that way for all parts. Ground you select the ground, hills you select the Hills and then apply the texture.
