normal VS pro edition
So...I"m looking at the Carrara program
What is the difference between the normal edition and pro edition?
See the following link
http://www.daz3d.com/products/carrara/carrara-tech-specs/
The main difference is the 64 bit version is pro only. There are many more additions that the link will show.
ok, thanks for the link
Huge.
For example, I really love the Ocean Primitive! Symmetrical modeling is a must! Although I could find a work around if I couldn't use "Edge Extrusion"
Oh... daughter is out of post op and in her room now - gotta go! :) :) :)
Don't forget Multi-Pass rendering and network rendering. The graph editor is technically listed as Pro only, though last time I checked you could access it with Standard. Pro also comes with the bullet physics library (Rigid and Soft Body dynamics). Plus Carrara 8.5 Pro comes with the Michael and Victoria 5 Pro Bundles.
