Asset/Product storage
Adruzo
Is there a way to store my DAZ assets / Products on a seperate drive from the program, or do they have to be on the same drive as the DAZStudio program? Right now DAZStudio is on drive (C) with all of my content. I would like to move all omy products/assets/content to drive (F) wich has a lot more storage space.
If you use DIM, you can change the download and installation folders in the Settings popup (not sure about Connect, I don't use it). Make sure the installation folder is also mapped in Daz Studio using the Content Directory Manager. There are several threads about this subject in this forum, so take a little time to read up on it if you need more details.
ETA: If you change the installation path, restart DIM to ensure it takes effect before installing anything.
Thank you. I will be sure to check out those other threads.
Yes, I always store everything on a separate drive!
You could either use DIM, as instructed above, or, if you prefer Daz Connect, just change Daz Studio preferences about the folder.
Speaking of freebies, just add their directory in the preferences!
Thanks again Northof45, I got everything moved and its all working perfectly
Great!
