Creating Templates
Hera
Hello!
Is there a way to create a template for an object which has none? To be able to use materials when the object in this case has no mat zones.
Post edited by Hera on
Do you mean create a template for existing UVs, or divide an already-mapped object into surface groups, or UV map an object that isn't? And which software?
If an object has no material zones, you're probably not going to get a UV map off of it without a mesh editor that can do such things.
Alternatively, you can use Daz Studio's Geometry Editor to select polygons and create surfaces (material zones).
UV mapping and being split into surface groups are not related,
