render won't complete
My renders won't complete.    I don't know how else to explain the issue.
Attached is a screenshot of my render settings and a bit of the completed render.  I've tried changing the minimum samples, etc. =[
Absolutely no idea what is going wrong.
  • BeeMKayBeeMKay Posts: 7,019
    You can check the log, but usually, increasing the Maximum render time, an D samples is a good start.
  • GnawsGnaws Posts: 44
    I found a(n awkward) solution:   Remove all Canvases.   Render went thru fine.
    Go figure.  =[
