Lost and Found
This is the first time I had this "Lost and Found" show up in my Smart Content. It started after I had installed some content through DIM, particularly Victoria 7 stuff. The one thing I made sure I did before installing any other V7-dependent content was that I installed the Victoria 7 Starter Bundle(Victoria 7 first in particular) and then installed the rest. Its the FWSA Grace HD for Victoria 7 that appears in the Lost and Found, yet the actor is also found where it should be. Is there any explanation for this? There was also another item that appears there, but haven't seen it lately. The odd thing about it is that to the right of the "Enter Text" box on the top, the file count is 0 when Lost and Found is highlighted, which to me indicates that the file isn't "lost" yet it shows up in the Lost and Found. And yes, the actor loads as it should. Screenshot below.
That's a metadata problem for Smart Content. You can manually categorize it yourself but I personally don't bother since I have more than 500 of those (old M4 and V4 items).
It isn't a problem, per se, but simply that there are items that have not been categorised. You can categorise them if they are things you want to find, but they may simply be informational (dummy presets with a hint in the thumbnail, for example).
As long as it was properly installed by DIM and is appearing in my content as it should, its not a problem and I'm happy. I had thought there might have been some files misplaced when the content was installed.
