Copy / Paste figure doesn't work right
Hello!
I have imported a Genesis 2 model into mixamo.com and animated it.
mixamo.com of course re-rigs the model, but I thought it would still work right.
No when I try to copy / paste the re-rigged model onto an original Genesis 2 Female model, everything works great, except the right hand.
Here is a screenshot of my procedure.
Does anybody have any idea what I could do to fix the problem?
Thank you!
Post edited by johann.hesters_2e9dd0ece9 on
  • JD_MortalJD_Mortal Posts: 760
    edited December 2018
    It could be hitting the "bend limits". Before you paste it, try removing the arm/shoulder limits for rotations. You could do that for all joints and save that model as your BASE MODEL, specific for this use. Then, you should not run into this problem again, if that is what the problem is.
    The limits are specific to each bones rotation. There is an over-all X, Y and a Z limit which needs unlocking.
    A little more complex... You could just paste the POSE, not the whole model.
    I don't think there is a setting to just unlock all limits, but I wish there was.
    Post edited by JD_Mortal on
  • @JD_Mortal You are amazing!!!! It was indeed the rotation limits!! Thank you so much for the wonderful help!
