Adding to Cart…
...the fog test illustrated that the case is extremely good at moving air though and out of the system.
Unfortunately most cases today have gone to the tempered glass side panels, fine for gamers who want to show off the guts with a light show inside, rather pointless for a serious CG production/render system
The P-193 I have (sadly discontinued) has not only a vent on the left panel but large fan there as well with a dust filter that really helps keep internal temps down to where I can get by without needing liquid cooling for the CPU/GPU. Also there is nothing inherently wrong with having a quiet system. My case has 7 fans yet is barely audible even during heavy duty rendering.
Everyone has their own preferences. From my experience over the years a case with more than ample airflow is preferable for a render workhorse that will be driving the GPU(s) at peak performance. There are other cases with side panel vents and fans out there (some on both the left and right side), but the game system build houses rarely if ever feature them as they look "too boring". You have to go to a professional workstation builder (more expensive) or BIY, the latter which the OP is does not seem interested in.
The fog test proved the case wasn't air tight. It did not prove that the air flow in the case was sufficient to cool an actual system. The fact that this is a discontinued case that be quiet dumped a bunch on ibuypower to rebrand should clue you in. The only reason to get this case would be if it was the cheapest option with an external drive bay if you wanted that there certainly are superior options for pure performance.
Side vents and fans have been shown to be pretty much irrelevant for case cooling. Air mostly travels in a straight like so adding fans or vents off that line does little and may even hurt cooling by affecting the force of that primary airflow.
Price are cheaper at cyberpowerpc
Check this one https://www.cyberpowerpc.com/system/Gamer-Infinity-XLC
Change the Memory from 16GB to 2x16 GB DDR4 3000Mhz and you should be around 2800$
If you want to further lower the price you can downgrade the CPU to a i5 9600K or even i5 8400 if you don't really need a lot of CPU power. The i5 is largely sufficient to run DS with Iray
You can end up with an appropriate configuration at less than 2700$. Also check the deals of the site
As mentioned by some other people, if you could mount the PC yourself, the price could further go down (in the 2200-2300 $ range)
...depends on the design mine is more efficeint at airflow than without. I can also reverse the side fan to become a fourth exhaust fan which would draw hot air out form the GPU area
Was not aware that case was discontinued.
..for 2,747$ I made the following changes:
8th Generation Intel i7 8700K
Corsair Carbide series Cse (this has a mesh front panel instead of tempered glass which is better for airflow)
Kit of 3 additional fans for upper vent exhaust.
32 GB (16 GB x 2) Corsair Vengence LPX 3200MHz
Corsair TX-M 80+ Gold 850 W PSU
I nixed the keyboard and mouse as they are oriented for gaming rather than CG production. Again better to get a standard mechanical keyboard (don't need one of the fancy lit ones) and a 3 button mouse or multi button trackball.
I would also suggest as an aftermarket installation, a second 3 GB HDD (for storage/backup). You can get that cheaper on your own and it is easy to install.
Another option would be to go to a place like PC Part Picker or Newegg, order all the components, then take them to a local shop to be assembled & tested if you are uncomfortable with BIY.
I absolutely second this opinion. If you spend $3,000 for a rendering machine, unless you are considering some professional application, is (like the Phillies owner) planning on spending stupid amounts of money for the performance you'll get (or even need).
Going to forums like these asking for opinions on computers or software is basically like arguing philosphy.
Correct.
AMD CPU with comparable or better performance for less cash.
I like a quiet computer, but yes, when rendering - I put up with the noise. But when not rendering, then silent.
Indeed; have it.
Yes, please. :)
+1
It would be interesting to see what you come up with.
Ok. I'll post them in a new thread.
