Resource Files
I have a question, which I have been meaning to ask for a few weeks but forget to get around to it.
When you buy a product and install it, does the DIM install everything you need or is it required to download the resource files found on the product's web page in addition to the DIM install?
Are the resource files extra content?
I appreciate your responses and knowledge sharing.
The DIM does not download these files.
They are texture template files, and are supplied so that you can make new textures for the product yourself. You would load the template into a paint program, and create your own texture sets using these. They are not required at all, to use the product.
I remember,, I asked same question in forum when I start DS ,,
I expected they should be additional extra contents, ^^;
Then,,, The resouce files in product page,
is UV template image (with GRID), to make new texture with the UV in your 2d paint tools.
Usually, you can use them as template layer, then your can make original texture map which fit to the UV.
bump, diffuse, opacity, normal ,,etc,,,
so that if you hope to make, you need to download from web.
DIM do not provide them.
lets check, download which you want to , then open by 2d vierwer.
