New items from the Shop does not install
Today a purchase a few items, after i download them all with theDAZ3DIM app, i realized a few of them was not installed in DAZ Studio.
I try reinstall under the installed tab in the install manager but they still not install it. Restart the iMAc several times.
But i miss under installed packeges columm the check mark.
How can i solved this is there workaround for this.
This contents was not for free!
If they are showing up as "Installed" under the DIM, but not under Smart Content in DAZ studio, it could be that they are older items that do not have metadata. I have a few items like that.
In that case, you can find them in the Content Library tab, but it is hard to say exactly where they end up. I find that using the search box at the top of the library helps with hard to find items.
Is it actually not isntalled, or does it just have no check mark? The check mark has nothing to do with the package's being isntalled - it indicates that the package has metadata for the Content Management System. If there is not check it may be a set without user-facing files (e.g. a morph expansion which just adds new sliders, rather than having presets to click).
Its not installed, this they have no check mark are also not installed, i cant find them in the smart object.
For explain a Hair bundle and a color add on both are not installed and alos not in the smart object.
Chezjuan it was in the content library thank you very much :)
Have you looked in the Content Library pane, in the Products list under the product name (e.g. Long Drifty Hair and Colors for Long Drifty Hair would be in Products>L>Long Drifty Hair and Product>C>Colors for Long Drifty Hair, rspectively).
