LAMH/LAMH Catalyst Not Working
When I went to render a sabertooth tiger with LAMH Iray Catalist, the fur showed up in the preview, but doesn't appear to render. Is this a bug I need to report or something I can fix?
  • FishtalesFishtales Posts: 6,218
    Make sure to use the render button on the catalyzer window and not the studio one that is normally used.
    Where is that render button? I don't have a catalyzer window (at least that I can find) and the LAMH panel doesn't have a render button
    2050 x 1468 - 668K
    Catalyzer is a separate plugin. The catalyzer fur doesn't render in the original LAMH programme.
  • aaráribel caađoaaráribel caađo Posts: 691
    edited December 2018
    I figured it out. I forgot that I had to enter the serial number to register the plug-in, so while it was installed, it wasn't active. Now I have the proper panel.
    Thanks!
    Post edited by aaráribel caađo on
    I am glad you got it working.
