Adding to Cart…
Here I've tried to save a Christmas tree in Daz Studio format. Should also work in Carrara, bit the shaders would have to be adjusted. There is a Carrara version earlier in the thread.
https://sharecg.com/v/92762/view/21/DAZ-Studio/Christmas-Tree-Daz-Studio-format-Reload
Here is an unrealistic palm tree. Carrara format. Enjoy.
https://sharecg.com/v/92766/view/5/3D-Model/Tree-Carrara-unrealistic-Palm-tree
Test rendering with two types of your trees with my just finished for now Tiger Moth
Wow, Stezza, somehow I am just seeing this. Great flyover. Don't think my unrealistic trees do your plane justice.
Here is the next fantasy plant. It includes versions of
mistletoe. holly. I had no idea that there were so many varieties of mistletoe, or that it was a parasite on other trees. I've included two files. One uses the plant modeler as intended to bemistletoeholly in the wild. Hang it upside down and attach to another tree. The other is a grouping of modeled branch and berries, intended for traditional scenes in which someone has used it to decorate a house or whatever. I'm posting themistletoeholly to the thread instead of at Sharecg. I've included the uvmap and diffuse maps for themisteltoeholly leaves.EDITED to address the labels holly and mistletoe.
See attached.
just saw the mistletoe thanks!! great job
If using the Christmas tree in Carrara, make sure to use the earlier Carrara version. The Studio DUF file is much, much more resource intensive.
its mistletoe!!!
thanks for this!!
You are welcome.
Here is another bush. This one has clover leaves (3 leaf). Again, unrealistic, with procdural shaders, not intended for closeups.
https://sharecg.com/v/92787/view/5/3D-Model/Carrara-Fantasy-Clover-Bush
Wow, soon we will be calling you Johhny Appleseed Carrara ;) thanks again., !
You are welcome. Starting to get a better feel for the modeler controls, and some of the limitations. Will be posting a few questions that I now have, especially regarding leaves.
Pease provide any feedback related to the tree freebies that I have posted, especially if you get any kind of error message. My emphasis of procedual shaders has been to minimize the potential for errors when shared. Going forward, I won't limit myself to procedural shaders. The mistletoe had some texture maps, which is why I shared it to the forum instead of ShareCG. The mistletoe's maps are good examples of things that I'm concerned could be a poblem when sharing.
slowly building up a forest! I have downloaded them all as I have most stuff on the forum, still finding time to render it all
tried to post the bark texture of my guava tree but it's too large for the forum...
I've been uploading images to facebook (copy and paste them from pse) then copy them and paste them int o my post here - might still be too big tho?
I downsized it by half....
also included the bump map for it.
This is amazing and I love the berry use!! And I will be using it... thank you so much.
But.... to me it looks like holly. Mistletoe might be easier to model as it grows in a ball on the tree with white berries for the ones I have seen, and no prickly leaves as in the image below. I have not seen it growing in a holly bush or tree though. I know I have seen vector images on the web of holly being called mistletoe, but not sure why.
Love your holly, though!
Silene
Mistletoe also country specific, we have mistletoe in Australia and a little mistletoe bird that eats and distributes it by poo but it's a different mistletoe to the European ones etc and grows on gum trees mostly
https://en.wikipedia.org/wiki/Mistletoe
and looking here there are an awful lot of different Mistletoes around
I actually grew up with a holly tree (not bush it was too big for a bush) in my front yard but of course in Adelaide it got the red berries in July, we used it a lot in flower arrangements.
sadly one day it just decided to die.
more bark as can never have too much
off my Jacaranda tree
Thank you!
Another Christmas tree, this time with tinsel. I created the tinsel using Philemo's plugin to convert hair to mesh. I deleted the strands that I gew the hair on.
https://sharecg.com/v/92793/view/5/3D-Model/Xmas-Tree-with-Tinsel-Carrara-Format
