New Capri Hair Renders only black with IRAY mats
I just purchased the new Capri Hair for Genesis 8. All mat options for Iray render black. None of my other hair products do this. Does anyone have any ideas? Is it a product issue? Thanks
Steve
Post edited by sjg_b28299fd86 on
This is the lightest blonde mat ...
I have the exact same issue. It doesn't seem to work with other hair shaders either. The hair stays black.
The hair has emmisive shaders. Turn the emmisive color to black for all surfaces in the surface panel and itll render just fine. Not sure how to use the emmisives yet...
...or why.
That does work. Thank you. Hopefully the product can be updated to use black as the emmisive color because I know I will forget this trick in the future. I have a help ticket open.
Steve
Example of Capri Hair.
Thank you! It has to be a mistake, though. I guess it will be fixed eventually.
gosh, i like the lighting you used here @anotherusername! what is it?
Has anyone put a ticket into support for it? It won't get fixed if they don't know about it.
It is light probe 03 from iRadiance - Light Probe HDR Lighting for Iray - Expansion 4, https://www.daz3d.com/iradiance--light-probe-hdr-lighting-for-iray--expansion-4 . I also wouldve played with the tonemapping some.
thank you!
Youre welcome jakiblue.
Yes, I opened a help ticket and it is now in their "bug tracker"
Will ping Jen to just double check she gets the ticket..
this has been fixed and should be live now
Just reinstalled main product and additional colors. Verified it is fixed
