@Sickleyield - it's time for thread about SY Splash
in The Commons
Time for a thread about this to show up.
Anyone get this to work yet?
What problems are you having, from the description it seems pretty straight forward to use.
Well it says to load it where you want it, parent it to your object/target and ...simulate!
Tried it three times and it isn't working (right). It's talking the shape of the character/object, but not dropping all the way to the floor and it's tilted slightly off.
Other dforce items work with more set up, so maybe the set up requires a little more than the loose instructions in the product description.
I don't feel like troubleshooting right now so I was hoping someone else had it, used it and could chime in.
I figure it should probably come with some kind of what-is-this simulation preset or such.
You mean the one that came out to day?
Did you use an anchored preset when you wanted an unanchored one? The anchored splats are set to have one end not move.
I have no idea. The read me wasn't a manual. This is the only set of instructions:
When you want something splattered on a standing figure, first pose the figure and then pose the splat approximately where you want it. Then parent the splat to the figure and tilt the figure backwards to sim, guaranteeing the splat conforms perfectly to the figure surface.
What presets? This product only came with props and shaders,
What about all the dforce settings?
Start from memorized bone position? Yes/No
Gravity settings?
Simulation presets?
So I should then, be able to place a PROP, let's say a smear or puddle, and place it it above the scene and use dforce simulation to have the object fall to the floor and conform to whatever it lands on?
Do I need to parent it to everything underneath it? What about multiple objects? Grouping?
Does scale have any impact on the simulation? and can every prop be used in any manner? Can I drop all of them?
Well that may be the problem, I scaled the small pubble into a huge stain. I'll try again and report back.
Hi. I can’t quite get this to work either and was wondering if you might be able to help.
This is me trying to use splatter 4 (unanchored):
This is when the simulation starts:
This is how it ends (perspective view):
As you can see, the splatter hasn’t draped over the body. In fact, it’s moved from the torso to (under) the right shin.
I haven’t tampered with any of the settings and can't see what I'm doing wrong.
Any help would be greatly appreciated. Thanks.
Don't delete your attachments after placing a bigger version in the body of the post, it will look OK to you as you have the cached versions of the files but anyone coming in later will not and the imaegs will be broken links.
I've attached the images so hopefully you'll see them this time.
Images removed due to nudity
Thanks.
Thanks for this.
I started with the body already prone. The idea was to show someone on the ground who'd been stabbed. The splatter seemed to go through the torso and slide down the body (even though, as the first picture shows (from the top view), it was positioned directly above the torso). Is the problem because I had him on his front rather than his back?
Thanks again for your help.
If they're going to be lying down you need to have simulate from memorized pose turned off.
Ah. I've done that now and it works.
Thanks!
