Which packages where download with DIM ?
I download Carrara 8.5 pro with DIM, think that all the content will come with DIM, but if I look to Carrara, no content like objects or scenes are in the folders.
Than I see that the native Content don't come with DIM.
I find 4 packages by ZAK-hair which have on the webside 147 mb and in DIM I have 3 packages downloaded with 106 mb.
My question is: Which content is downloaded with DIM and which must I still search out and make a manualy download?
The Native Content does come with DIM. In fact if you used DIM to install Carrara 8.5 then installing the Native Content with DIM is even easier. Please read through the Carrara 8.5 Setup Guide
Thanks, i find it.
It was the Download Filter.
:red:
If I had a nickel for every time that happened to me... well I'd probably have about a $1.00. It has definitely happened to me a time or two. I'll be waiting for something to show up in DIM and I keep hitting refresh - nothing. Then I realize I have a download filter set.
I was sensible I went and took ticks out of everything that was not Carrara while I set up 8.5
I better check I put them back 8-/
