How do I load this model into Daz Studio?
I installed this model but I can't figure it out how to view it in Daz
https://www.daz3d.com/star-2-0-for-genesis-3-female
Post edited by Chohole on
you have 3 options once you purchase it, you can either use DIM Connect or install it manually.
You then load a Genesis 3 female character, negotiate to the character library and apply the charater morph to your genesis 3 female.
I have a problem with this window, I can't figure out how to close it so I can acces the library.
If you just want the shape or some of the shape or the extra morphs you will find them in either the Parameters or shaping tab under Star when you have the figure selected.
Thanks for the advice. The Shaping tab doesn't give me any options when I click on the model but the Parameters tab does. Do you know if that model has custom pre-made shapes and morphs like in the picture? and how do I add them on the model? I'm trying to give the model some anime shapes.
That isn't a window, it's the place-holder What Do I Do page - if you select a category on the left, such as Figures or All here, it will have something to display there instead of the instruction text (which will then will go away).
I'm having Isues loading the model, when I click the Daz library >>all file>>figures>>people>>female I only get :
Genesis 8 Female Dev
Genesis
Pin up
Super Girl
but not the custom model.
I am only able to view the model If I doble click on the icon of the model inside the folder where I extracted it but it only shows the model in standard body not manga/anime. Does anyone know how to fix this?
Sorry for newb questions. I never used this program before.
You should be able to see evrything installed in alphabet order in Content Library tab under the Product list as seen on the screen. Maybe your problem is due to the fact some artists use different folders to install their content this way you can find morphs installed at 2-3 different places and even in separate folders under the artist name.
Edit: In this case you it is a Gen 3 character, not Gen 8; I guess you will need the folder named "Littlefox"; If you don't find it under the Products as written above I suggest to search your content library for "Littlefox" folders
Edit 2: silly me - just download the product *manually* from your account, open it with winrar or similar w/o extracting it and copy down the instaltion paths.
I think my first problem is that Genesis 3 female does not load, it only gives me this error :
and when I search Littlefox i still can't find anything.
In the Products tab of Samrt Content find Genesis 8 Starter Essentials and right-click on it - the menu, if you are in the right place, will include either Install or Uninstall. If it has Uninstall, select that - otherwise, cancel.
Thanks that helped!
