Will these 3DL texture sets work in Iray?
Charlie Judge
Will these texture sets work in Iray?
https://www.daz3d.com/opulence-for-classic-deco-eclectic-2
https://www.daz3d.com/moonlit-moonshines-diner-interior-noir
Thanks
Post edited by Charlie Judge on
The stuff with actually textures should look fine, although the shaders may need some tweaking after applying the Iray base. However there is an awful lot of metal in the scenes, and this is going to look a lot better with a proper Iray metal shader applied instead.
I tested out Opulence.
Converted it via RSSY 3DL to Iray Converter.
Selected the lights, made the glass glow.
Made metallic fixtures metal (set Metallicity to 1)
Selected mirrors, made them mirrorish. (Metallicity 1, Glossy Roughness .1)
@ Oso35: Thanks for testing it. I knew some tweaking would be required; I just wanted to be sure the textures would "carry over"
