Show us your 3Delight renders
Adding to Cart…
Thanks.. They do seem to compliment each other quite well...
...the proud owner...
Angel The Goddess Warrior........and her nemisis Nybras!!
Morning Out.......Looking for a friend.
It is the Unsed Railway Bridge it is great set for sure.
I am glad you liked my "Morning Out"
...so I fixed the dude's jacket, quite happy with how it turned out:)
IBL Master Render
Right you are:) Maybe I should have converted to awe?
Vespertilio Cinis
This is Stonemason's "generic sci fi corridor" that I purchased 10 years ago.
I wanted to see how it looked converted to AWE and only use the "light" material zones for lighting.
Naturally, all those bits and bobs of geometry converted to emitters made for a very long render - but I think it turned out pretty well.
Sure did;) And no grain, very nice!
For faster renders, use a plane and instanced as many as you need. Separate the emitters into logical groups (shape, light color or intensity). Pretty much behaves similar to light groups. The align tool in DS helps quite a bit if the emitters are spaced evenly.
Testing out the RC version of the update.
I know I should use emitter planes and I will be doing that for the next setup - but, as I said, I wanted to see how it would go using just the material zones that came with the model.
Now I know.
Just saying.
The updated shader(s) will also let you animate everything - colors, temperature, intensity, falloff, barn doors. I'm wondering if it is feasible/possible to use texture sheets. It should be, but I need to work out a scheme to make sure loops behave correctly regardless of frame rates or loop length. Maybe even do some blending between each tile in the texture sheet.
Here's a good look on how it's implemented in Unity.
Interesting! Tks for sharing:)
Just to be clear, aweShading Kit 1.0 for Daz Studio renders are welcome here.
I dabbled a little with Luxrender, took a brief, horrific stab at iRay, and am quite content to sit in my 3Delight puddle and play :-)
Same here @Misselthwaite quite content to stay in my 3Delight puddle and play around in it!!
Whoa... what's granny up to, there? :-D
Not very exciting, this one.. just testing a few things...
Good landscaping is always exciting! What did you use for the trees in the background? I really like your lighting, I have trouble with the great outdoors :-)
Thanks
That’s a test of a mesh generated by photogrammetry.. the trees are from the Ecomantics sets.
Sorry! English is not my first Language. I will remove the picture.
