Hiro 4 Eyes Problem
Hi! I need to work with Hiro 4 again in Poser after some years I didn't use him. I downloaded from my Daz Library and installed manually in Poser Pro 2014, but when I loaded him, I noticed some problems with his eyes because they are too small for the big head of Hiro, like I show in the attached picture.
Plus, I remember when I loaded Hiro, he was thin and now, Poser loads him like same body type like Michael 4.
How can I solve the eyes problem and make the body thin again? Btw, I tried it in Daz and I have the same results.
I hope someone can help me guys. Thanks!
  • LeanaLeana Posts: 12,919
    Usually this kind of problem with M4/V4 morphs means that you need to run the morph initialization script (the DzCreate ExPFiles-v4.bat script and its M4 equivalent under Runtime > libraries > !DAZ)
  • faisanfaisan Posts: 600
    And how can I get that file in order to run it?
    edited November 2018
    It's installed with V4 (or M4). You need to run it after installing the various morphs packs (head and body morphs, base characters like A4...) so that the figure can use the morphs.
    Post edited by Leana on
    Ok! I got it! Thank you so much! You helped me so much!! :D
    Post edited by faisan on
