Content Creator Toolkit?
I've seen a couple of references to a "Content Creator Toolkit" within DAZ Studio, which it appears you make clothing and do other neat stuff with, yet I can't find such a thing. Is it something in DAZ and how do I find it?
If you have entered your serial number, so that you ar running daz Studio pro, you have the content creation tools available. They require input - a model of clothing created in an external application, for clothing creation, which the tools can then be used tot urn into a conforming rigged figure.
Thank you. I seem to have Pro, and I believe I found at least some of the stuff under "edit."
The Transfer Utility and the Morph Loaders too, plus the Joint Editor, Geometry Editor, and Node Weight Paint Brush tools and the Figure Setup and Property Hierarchy panes.
