DreamLights Light Dome Pro-R
Does any one know if Light Dome Pro-R works with Daz 4.10 pro 64bit. i know on the product page it says it is compatable. however my whole daz application crashes when i hit render button. i bought the first light dome pro and nothing install only a folder with some skydomes nothing else. i then bought and installed Pro-R, i follow the tutorial but dont have half the content that is in Dreamlight folder. I know u have to use this with 3delight, again that was not stated on the product page i only found out by threads. Even changing to 3delight the whole system crashes. So i have wasted enough money on lighting and i have now bought 2 dream light dome pro's that dont work on my system. Do i need to down grade to Daz 4.10 non pro version if that possible, or change to Daz 4.10 32bit. i have no idea how to contact dreamlight directly.
Anyway thanks in advance.
yup just tried it with 4.10 beta, no problems! You need to first choose 3Delight, then use the included LDP-R render script to render out your scene.
The script will create a folder and place the rendered images there automatically. You then need to import them into an image editor (Photoshop,Gimp) and blend them together as needed. Set the background layer to normal and the other layers to additive, go from there!
Here is a quick one:
Your best bet is to file a help ticket and ask CS. https://helpdaz.zendesk.com/hc/en-us/requests/new
thanks for replying yes i have tried with just one 3delight prop. and it worked but when i added buildings and figures (all in 3delight shaders) it just kept shutting down. so i have given up now but thanks for ur help.
Hey, I bought the same product, DreamLights Light Dome Pro-R. My problem is that the skydome doesn't get rendered. Anyone knows what's going on? I'm on Daz 4.11, by the way. When I hit the LDP-R Render, and I'm on the LDP-R camera, it hides the skydome right away. This is really frustrating.
