General Freebie Requests
Adding to Cart…
Thanks kerya, lots of weapons for me to look at! Although it's sad all of runtime's freebie links are broken =(
Thank you, Vaskania, SteveM17, and Eustace! I suspect I'll end up using parts of all three of your suggestions.
Where can I find a graduate hat and a diploma prop please?
http://www.sharecg.com/v/68624/gallery/21/DAZ-Studio/Genesis-Graduation-Gown
This one have the mortar board and scroll.
And there's a Poser version of a mortarboard hat here:
http://poserfreestuff.zenryokuhp.com/detail/aglwb3Nlcml0ZW1yEgsSCUZyZWVTdHVmZhih5uUBDA.html
OK, not often I do this, and I am sure this has been asked for before, but I need leg calipers (braces if you prefer). The sort that they used for polio victims, back in the day.
Anyone got any ideas please. Preferably for a child, but I should be able to work with any if they are props.
I have a set of Genesis Martial Arts poses I downloaded a long time ago, and don't remember the URL for them, and need it for the Freebie Contest. The folder they're in it named GJ Poses, and includes the pose in the image attached below. IF anyone else has this pose set and has the URL link to it, I would be most appreciative.
Here:
http://www.sharecg.com/v/60797/browse/21/DAZ-Studio/Genesis-pose-mix-one
Here:
http://www.sharecg.com/v/60797/browse/21/DAZ-Studio/Genesis-pose-mix-one]]http://www.sharecg.com/v/60797/browse/21/DAZ-Studio/Genesis-pose-mix-oneYep. That's the set I was looking for. Thanks.
How about taking a pair of long stockings say like the LD Stockings and then creating a texture and trans map for them. It is a lot of work. I remember BWSMan looking for braces last year for one of the months maybe he found something. Here is the link to the stockings if you don't have them:
http://littledragon.francemi.net/misc_01.htm
Gillterati's Ruffle Dress has tights for K4
http://www.renderosity.com/mod/freestuff/details.php?item_id=69011
If I can't find anything I shall try making something with prims in Bryce, but would be easier if there was something around.
chohole what era are you looking for?
there are several styles and it depends on 1 leg or 2 and if you need the hip belt
for the most part it would be an easy model to make dependant on the type
also leather and lace-up or buckles?
or the more modern velcro style with multiple straps and carbon fiber?
boot attached or not?
Does anyone know where I can find a prop/model of a treasure pile? The sort of thing you might find in a traditional dragon's cave?
Zenrel and RobKelk, thanks a lot. Thanks exactly what I need! SteveM17, there is a prop you may find useful for creating gold piles (you'd need to multiply the model): http://free-poser-daz-studio.blogspot.com/2007/07/free-poser-daz-studio-free-gold-bar.html.
Don't know where to find a complete treasure pile, but here are two chests full of coins which could be a start or a complement to it:
http://www.renderosity.com/mod/freestuff/details.php?item_id=67650
http://www.renderosity.com/mod/freestuff/details.php?item_id=39562
Does anybody know where I can find a Poser or DS format pulley? Just the wheel itself with nothing else (or with other parts that can be hidden would work too.)
Spacebones has some primitives that could be made into a simple pulley by matting two rings together. The picture is two ring 40s back to back.
http://www.sharecg.com/v/9915/gallery/5/3D-Model/Profiled-Rings
If you need the center pin then Spacebones Rounded Edges has a cylinder that would work well for the center pin of your pulley, cly25.
http://www.sharecg.com/v/12780/gallery/5/3D-Model/Rounded-Edges
This is a block and tackle. The material zones are not set up for just one of the pulleys so you would have to take it into a program like Hex or Carrara to remove some of the geometry so that you would just have the pulley.
http://www.renderosity.com/mod/freestuff/details.php?item_id=63061 This is in pp2 and pz3 format.
Hi! I'm having trouble looking for what I need mainly because I'm not sure what to call it but basically what I'm looking for is something like a scarf wrapped around the head or something like a swimming cap maybe? Any help would be appreciated. Thanks! :)
Do you have a photo of what you're looking for? And which character or characters will be wearing it?
Oops, sorry. I meant something like this white one from Novariens Holy, or something like the Girl With The Pearl Earring, for V4. Thanks!
Is this what you're looking for?
http://www.daz3d.com/forums/discussion/27437/
I need a morph (or something) that will let me remove the front teeth from the K4 figure. There are several for V4 but I can't find anything for K4.
V4 morphs will work on K4. If it's an MT, use the V4 mesh as a contrary MT, thus: On body, V4-shape = 0; on head (or other targeted part), V4-shape= -1, desired-MT= 1.
Alas, I've seen it beforehand too but no. I think a tight turban or a swimming cap is closer to what I need. Thanks though!
Hmmmm
http://www.sharecg.com/v/54886/browse/11/Poser/V4DrapedHood
or
http://www.sharecg.com/v/63011/browse/11/Poser/Fur-Caps-for-M4
retexture the fur brim?
or
http://www.sharecg.com/v/48847/browse/11/Poser/Vulcan-Cap-02-M3-V3-M4-V4
Thanks for the response, Eustace, but is this for DS or Poser? I use Poser 7 and I'm not entirely sure I understand what you are proposing. I assume "MT" stands for Morph Target, but do I inject the V4 morphs onto the K4 figure or is there something I'm missing (other than a brain!)?
If I'm dealing with a Gen4 figure and a Morph Target (yes, that's what I mean by MT) for another Gen4 shape, I'll load the originally intended figure (V4 in this instance as a full-body morph MT into the targeted figure (K4) and set the morph to 0.0%. Then I'll load the MT for the specified part (a head shape, let us say) and set it at 100%. At that point, I go to the targeted body part, find my V4 morph (part of the Full-Body Morph from earlier) and set it to -100% or -1.
(K4/V4) * (V4/MT) = (K4/MT)
There is also a CR2 offered at ShareCG to let one mix INJ-morphs on the K4 base: http://www.sharecg.com/v/45885/related/11/Poser/Mix-K4M4V4-morphs
Anybody know where I could find a two-man saw like lumberjacks use to cut down trees?
Thanks in advance.
Maybe joe's meshes will work for you. He has a V4 gsuit that covers the head and face. It is here:
http://www.sharecg.com/v/67360/gallery/5/3D-Model/Quicks-Quick-Resource-Meshes
In his V4 Sci-Fi Armor he has a head sock but the ears have a bump out. It is here:
http://www.sharecg.com/v/50021/gallery/11/Poser/V4-Sci-Fi-Armor
Mamomamo has a ninja suit with a head mask that is mapped. You could build a transmap to give the face opening your choice of contour and remove the tails if you did not want them. It is here:
http://mamomamo.candypop.jp/Freestuff/CCP012.html
Also A::DP has some wonderful poser dynamic hoods if you want the other piece in your picture. He has them designed so that they can be used in DAZ with a little tweaking. He also has a fantasy costume that has a cap incorporated into the dress and with your skills I think you could use just the cap. I am linking to his gallery cause there might just be something else that you could use.
http://www.sharecg.com/pf/full_uploads.php?pf_user_name=adp__
I need some help from you creative clothing types. I'm looking for British Army officers and battle dress uniforms of World War 2 for Genesis male and female.
Please look here: http://www.sharecg.com/v/27632/browse/11/Poser/M3-Normans-Outfit
