How to fix a crooked mouth
galactica1981
I created a V4 model using FaceShop but the mouth is crooked which means I can't give her different expressions because it looks distorted. Is there any way to repair the mouth on a morph?
Post edited by galactica1981 on
are you using studio or poser?
DAZ Studio
ok, no idea what might work in studio, i know something that may or may not work in poser
:ears perk up: I have a similar issue with a morph I made using a combination of Faceshop and CDI's Morphia/Morphus. It's okay on M4 but when I use the V4 version the lip is a bit off on one side. Been faking it as much as possible with other lip and expression morphs but I'd really like a better fix, other than trying to recreate it again from scratch. I use Poser, here's what it looks like on V4. The one without the hat is before my fake fix, the version with the hat is the best I've been able to get it after. Any advice greatly appreciated.
in poser ( i have no way of testing this at the moment ) i would try using the morph brush, i wouldn't morph anything, but the tool has a mirror left and right feature, i'm wondering if it will work in this situation
Hm, couldn't hurt to try, though I haven't used that particular feature much. I did try it once when I first noticed the "bad" side of the lip, thinking I could push or pull the corner into the proper place. But all I managed to do was produce one heckuva wart. :red:
