Genesis 1 Eaten by Hideous Troll
OMG, My Genesis 1 has been devoured by something that looks awfully like me after a bad night! Happens for all versions of Genesis 1, tried uninstalling and re-installing, putting all actors to Zero, still there!
Whatever the shape it is loading with is, it has been (re)saved with a non-zero default value. Look in the Editor tab of the Parameters pane, under Curently Used, and you should find the culprit - if it's a third-party morph try reinstalling, if not (or if that doesn't help) click the gear icon on the slider>Parameter Settings, set the Default value to 0, and use File>Save As>Support Assets>Morph Asset to resave just that morph (with its default settings).
Thanks for the input, sadly no joy, the Editor tab on mine is under shaping and I can use it to dial out the Orc-ness or easier use the Zero option in the pane menu or main EDIT menu. but saving the morph asset does not help, it comes back when I load again.
Checked the logs and the basic female appears to load, then there is a flurry of activity regarding dzassetdaz.cpp loading stuff, and some of it failing, that refers to "GhostofMacbeth" Orc settings, which I have not installed so cannot uninstall. Tried searching for dzassetdaz.cpp which I assume is a C++ file with a view to editing it but comes up nothing found. Also checked the GENESIS.DUF file, but nothing odd in there and no scripts attached in any menu settings I can find.
One thing I cannot explain, I notice when saving the Morph settings it says it is using the ANDREA file, which I have not loaded, my basic Genesis is LANA based.which I assume is standard as I never changed it.
Yay, fixed it. Happened to notice that when uninstalling Genesis for about the sixth time the actual files were still present, eg Genesis.duf, so deleted all the start files for Genesis then went into Data\daz 3d\base and went nuts deleting anything genesis there and installed again. Now all genesis based characters are working, including my favourite: Victoria 5.
Can only assume one of the freebies I downloaded injected (literally) some Orc into my lady.
Had you zeroed the Default Value in Parameter Settings? Parameters will have its own Editor tab, with a Currently Used group - Shaping and Posing are just sub-sets of the ful Parameters pane.
