G8F Morph Loader Pro modifications - clothing and eyelashes do not fit after reload
I loaded g8f, change to base mesh resolution, subdev level 0, delete eyelashes, export to wavefront (obj) with all appropriate settings.
I modify character in blender, make legs and neck longer, body slimer, and export to wavefront (obj) with all appropriate settings.
I load g8f in Daz3d, open Morph Loader Pro, apply my morph with positive confirmations (no errors and geometry mismatches), crank it up to 100%, rigg it, apply ERC freeze, so far so good, no problems.
I load a few garmets, check eyelashes, all fit perfectly: eyelashes are hugging eyes on elongated neck, shorts are hugging waist and legs, all perfect, save it as scene or subset.
PROBLEM: reload character from scene/subset, eyelashes are not fitting, clothing is not fitting to the new figure with 100% dialed morph (everything fits original g8f shape, see picture attached) Please help!
  • RedzRedz Posts: 1,459
    You need to save your new morph as a morph asset. If it’s only saved in the scene file the autofollow is breaks when you reload the scene.
    Thank you Redz, it worked! Countless hours figuring out why it brakes the entire set...resolved with one line of brilliant suggestion. To sum up for somebody who has the same issue:
    I loaded G8F, than imported obj via morph loader pro, dialed it to 100%, rigged and erc freezed it, edited morph (name, color, 0-100% etc) and then saved it as morph asset in Actor/Full Body/People/Real World.
    And now I can take new G8F and just dial that morph with no fear that all resets itself after character reload...Thank you!
