Exporting Fibermesh from Zbrush to Daz3d 4.9
GreenBean
hey guys!
i have tried as hard as i could to try and export the fibermesh from ZBrush 4R7 P3 into the Daz studio, i just can't figure out how!
i am trying to give the Genesis model a custom haircut and custom body hair.
i would really appreciate any help or a small tutorial that could show how it could be done!
Thank you so much.
DAZ Studio
1 - select object
2 - Press GoZ
Zbrush
3 - use masks to mark areas for fiber hair
4 - create Zbrush fiber hair preview
5 - change parameters of Zbrush fiber hair preview to get the look you want
6 - Confirm the fiber preview hair curves to be converted into actual fiber mesh geometry
7 - use brushes to comb the hair geometry into position
8 - in the subtool menu select the fiber hair
9 - click GoZ
DAZ Studio
10 - import dialogue add fiber hair as new object
11 - save scene
At which exact step have you been struggeling?
In any case make sure to watch all the fiber mesh related videos in the ZClassroom:
https://pixologic.com/zclassroom/workshop/fibermesh
and the basic GoZ tutorial video for DAZ Studio
https://www.youtube.com/watch?v=mFRUVZHW_hw
Follow up:
If you want to create hair for different areas like body and head you can either
- export the fiber hair with GoZ one after the other by selecting one fiber mesh subtool, GoZ, select next fiber mesh hair subtool, GoZ
or
- merge all the fiber hair subtools before exporting with GoZ
This image is an example how multiple fiber mesh hair layers were added together:
After GoZ from Zbrush to DAZ Studio the first layer of hair did not seem thick enough.
I could now just have restarted from scratch.
Instead I choose to actually make a second layer of fiber mesh hair and combine it with the first.
In addition there are addtional layers of hair for the ears, chin, brow area with different lenghts.
The final coloring of the hair was done in the OctaneRender Node Graph Editor. Experiment with some turbulence, noise or any other fractal nodes to create random patterns.
And last but not least:
If you do not show the whole object in the final render only create fiber mesh hair for those areas that are actually visible to save valuable space in system RAM and VRAM.
i love you so much!!
thank you so super much!!
i have this bookmarked now!
Thank you again! <3 :'D
I have the Zbrush tool selected and hit GoZ, and instead of placing the object in DAZ 3D 4.9 which was open, it instead opened up an older DAZ 4.6 (MAC IOS), which is not what I wanted. I closed DAZ 4.6, deleted the application, went back into Zbrush, hit the GoZ button again, but now, nothing happens. How do I get Zbrush to point ot ht e latest version of Daz3D
I created a new thread for updating to ZBrush 4R8.
The steps described there hopefully help you to solve your issue as well.
https://www.daz3d.com/forums/discussion/177371/zbrush-4r8-and-daz-studio-4-9-4-117#latest
Do you know a good tutorial to create hair with fibermesh for genesis ?
I would love to know how to UV map the hair to match the underlying tool (model) it was grown on, fiber mapping vertically maps each shaft in overlapping UV's great for head hairs not for animal furs.
- Specifically for Genesis: No.
- Fiber hair tutorials from the official ZClassroom:
http://pixologic.com/zclassroom/workshop/fibermesh
Very good question. So far I worked around that challenge.
So the short answer is: I do not know.
What I can share is how I worked around it:
Custom Fiber Hair Shader for Octane
I created custom hair shaders for fiber mesh hair in the Node Graph Editor for OctaneRender.
-> Experiment with some turbulence, noise or any other fractal nodes to create random patterns.
-> Experiment with "projection" modes and UVW transforms
Basically projection modes work live different UV wrapping modes. The difference is that you can change the projection after the texture was created.
In addition to just UV there is also the third W axis -> UVW
You take a texture with an existing UV and "project" it on the surface similar like a different "UV wrapping" mode.
- Switch between 2D UV and 3D UVW projection modes
- Switch beteen object and world space
- In addition use nodes like scaling, tiling etc.
Custom Fiber Hair Shader for Iray
You might be able to create a custom hair shader for fiber mesh in Iray.
With "custom" I mean that you create you own shader with MDL (Material Definition Language) nodes in the DS Shader Mixer.
3rd party apps
Some older 3rd party forum posts talk about 3rd party apps that can generate colored textures for ZBrush fiber mesh hair based on the body texture.
"Look at my Hair"
When you create Fiber mesh hair as a separate obj geometry with "Look at my Hair" a set of additional textures is created which seem to use the body texture to color the generated fiber mesh hair.
- Apply the body texture to the original object.
- Apply the fiber mesh textures to the fiber mesh groups.
The three left ones are fiber mesh hair textures
The one on the right is the body texture.
-> Try asking the "Look at my Hair" developers how they solved the challenge and generated the colored fiber mesh textures...
-> Does anyone else have the answers?
well I sort of solved my issue at least
if I use the packed UV option I can save a textured pelt I paint with polypaint or coloured using Zprojection from an image
I did this Squirrel prop, video, very fast low quality iray render
it maps like this
Could you describe how you did this, Wendy? Many thanks!
