hair poke through
okay as you can see i am using charm hair i have poke through and it doesn't lay flat either i have the sliders up to show you what i a have
Please give the poor girl enough clothes to not be nude.
The hair isn't dynamic (we ave only a few items of hair designed for use with dForce) so it won't shift to accomodate clothes or poses - there are, however, movement and styling morphs which will be visible in the Parameters pane's Editor tab when the hair is selected and you should be able to use those to imrove the situation. If the morphs are not enough the next step would be to apply dForms to manipulate the mesh directly.
