Nvidia drivers 416.94 some changes and results
hi,
the first good point with the new version drivers,
is the ability to see the GPU process in "resources" of the "task manager" (finaly)
the other point about the use of the GPU process
i noticed (after several render test) rendering in Iray, the GPU process never reach 44% (from 30% to 44%)
i try with or with out CPU checked in render setup, the % iresult s the same
the question is:
there anything i can do to use more than 44% of my GPU ?
- when checked, the CPU always use the maimum 99% to 100%, unchecked CPU use only 23%
I7-8700 - iNvidia "1060" - 32 GB mem
Post edited by cm152335 on
ppossible false report,
after reboot my PC the task manager not show GPU process (1%)
the feature is unstable
EDIT ADDED
found something abnormal
after reboot, my video drives goes back to previous version
checkin nvidia updates the version 496.94 is proposed to updates from 496.81
EDIT ADDED 2
reinstalled again last drives 416.94, the task manager GPU process is back (31%)
see pic
finaly i found,,
the process when IRAY render it use full GPU (95%-99%)
the "3D" process always remain at 1/3 (33%) of the use (left top),
to show the real render process, I select "compute_0" from menu (right top)
it need to change what you want to see from roll menu (via 12 choices in my case)
