problem with genesis 3
hello anyone. I have to resolve this problem....When i open a genesis 3 character, i have first this message: " duplicate...." you can see in photo.
Thank you for your help.
This is usually an issue with content - either one product with bad set-up, or two products that are OK in isolation but which have used the same name for one or more properties. If you go to Help>Troubleshooting>View Log File and search for Duplicate, starting from the end, you should find entries which list one of the products and tell you the names of the probler properties - please copy those lines and paste them here.
I've always been curious about this. Since the files always load anyway and nothing seems to break... what's the worst that can happen if I ignore the error message?
The second of the conflicting property links will not load, and I think the second of the morphs (if the issue is two different properties with the same name) will not load.
