Material Preset - Saving modified surfaces only
MBuschMBusch Posts: 547
I am trying to re-save some partial Material(s) Preset and in the Save dialog box I get the option "Check All Modified Only". Fine, but all surfaces are partially checked because Normal Map seems lack a default state.
I am attaching some screen shoots to make it clear. In the Surfaces pane you see just the currently used parameters. As you can see, it shows me 24 surfaces with Normal Map used, which is false. So at the Save as Material(s) Preset dialog I am getting all surfaces with a check mark even so I know that are only 5 surfaces with modifications. How can I just get this marked correctly?
Post edited by MBusch on
