MRL Amara Braids for G3F-similar style but shorter on the back?
in The Commons
Hi,
https://www.daz3d.com/mrl-amara-braids-for-genesis-3-and-8-female-s
I was looking at this product but I dont see a morph option to make the hair shorter on the back and all the preview pictures show it having the same long length of hair. Does anyone know for sure if this hair product has an option for shorter hair in the back? if not are there any other hair products here or on renderosity that has the same braiding style on the scalp but with shorter tails on the back? I saw a few but they had weird braiding patterns. I wanted the type that has the braid going straight from the front to the back.
thanks
No shorter hair option unfortunately.
These aren't quite what you're looking for, but they're as close as it gets. The difficulty with all of these is going to be that they were made for Genesis 2, so if you use Autofit to fit them to Genesis 3/8, you're going to lose all of the special bones. It would be best to parent them, if possible.
https://www.renderosity.com/mod/bcs/khc-boxbraids-g2f/118133/
https://www.renderosity.com/mod/bcs/khc-cornrows-g2mf/120360/
https://www.renderosity.com/mod/bcs/khc-tiger-braids-g2fg3f/121275/ (these have a G3F version, so you can make them work on G8F just by changing the scene identification WITHOUT fitting them to the character first -- see this tutorial for more information; while it has "clothing" in the title, it also refers to hair: https://www.deviantart.com/sickleyield/journal/Tutorial-Convert-Clothing-G3-to-G8-G8-to-G3-686682065)
Probably not quite what you're looking for, but:
https://www.daz3d.com/rasta-tails-hair-and-oot-hairblending-2-0-for-genesis-3-female-s
https://www.daz3d.com/quincy-hair-for-genesis-3-8-female-s
https://www.daz3d.com/havana-hair-for-genesis-3-female-s
Hope these help some.
The second one you linked is actually exactly what i'm looking for style wise and also length wise at the back of the neck. I'll give that one a try and make it work.
Thank You
If you uncheck limits for the length morphs, you should be able to make the braids shorter.
I didn't see a length morph on this hair
The only short corn row hair i've ever seen was Ony Hair which was for G2F by Aeon Soul. I have it from testing at rdna. If you can find it anywhere, or if they still have their site, maybe you'll get lucky. Otherwise you might be able to make transmaps for the Samsil hair or one of the other corn row hairs.
Edited--Samsil does have a short corn row hair.
