using cube to rotate figure
good mornig. escuse me for my little english. i have this problem: when i use cube for rotation or gizmo or morph cursor , the figure disapears and i have only this ...... tank you for help
Post edited by perlecosemie_391cc66953 on
  • barbultbarbult Posts: 26,518
    edited November 2018
    Open the Draw Settings pane. If you don't already have it visible, you can open it from the Window menu. [Window/Panes (Tabs)/Draw Settings].
    In the Draw Settings pane, click Manipulation in the General section. Change Manipulation DrawStyle from "Switch to Wire Bounding Box" to "Use Current (Off)".
    878 x 652 - 28K
    Post edited by barbult on
  • tank you. you are great. a KISS. All right
