Bride's Gold missing parts
There is only one item in Bride's Gold. Is there a way to fix that so we can get the full set of objects on download?
  • FSMCDesignsFSMCDesigns Posts: 12,846
    Best to put in a support ticket rather than post in the forums, you will probably get quicker results.
  • LindseyLindsey Posts: 2,009
    Mine was installed with Daz Connect and came with 14 props.
    1014 x 847 - 266K
  • KinichKinich Posts: 925
    I suspect you use the Content Library rather than Smart Content, I do the same, in this case some products don't transfer into the content Library Categories section correctly from the Daz Studio Formats Section, they're present in the Formats Section but when you try to categorize them not everything copies across, why this happens I don't know but the only fix I have found is to uninstall, and reinstall and recatergoize the item, even so I don't have 100% success but the best hit rate comes when I use the method below:
    1. Delete the Entry from the Categories section.
    2. Close Daz Studio
    3. Uninstall product via DIM
    4. (Optional) Delete from DIM & Re-download product, this sometimes helps if this method doesn't work first time if you skip this step.
    5. Install the package again & try categorizing the product.
    A bit of a pain but it's the only solution I've found that works for products that don't categorize correctly first time around, and Brides Gold was one I had problems with, but it's now correctly categorized and working after the above method was used.
    I can't guarantee that this will work, I've had a couple of products that need a couple of reinstalls and a couple that I simply can't get to transfer across correctly, even though they are in the Daz Studio Formats section and do work from there.
  • Joe.CotterJoe.Cotter Posts: 3,362
    Thanks kinich I think I'll try uninstalling first and then reinstalling with Daz connect to see if that fixes it if not I'll try your solution
