G8 wearable armpit issue
Hey!
I want to make a shirt for g8f but I'm not able to get a clean result in the armpit area. When I raise the arm to the limit there are always some strange deformations. I tried to repaint the weight map but I'm not even get close to a acceptable result. I also tried different settings in the transfer utility without success.
First image is a test-shirt with copied vertex from g8f (with removed sharp edges, but it doesn't seem to make a difference). Second image is a own model made out of a cube in blender.
Does anyone have ideas?
thank you!
