Is there any Utility for DAZ 3 or 4 to smooth out animation?
I have some aniblocks, they're great but they're not that smooth, i would like to be able to smooth it out.
for example a walk aniblock.
Is there any free utility out there that can do that.
I tried mcjDecimator but it doesn't work. it makes the walk shorter and then it stops and also it makes it like float slide through the floor. it's no longer a walk
mcjCycleFilter is a pretty good script that allows smoothing with splines.
There are a whole series of scripts from mcasual here:
https://sites.google.com/site/mcasualsdazscripts2/home
Do you have experience using this utility. How do i use it? it's complicated when i read the manual i don't get it. but i tried just pressing apply and i don't any change. my animation is a walk
The smoothing is a feature of your Frame rate the Default is 30 frames per second in DS. I can go as low as 24 frames per second in both Animate and the DS Timeline with no errors.
What are you seeing?
EDIT! These are Hand made AniBlocks? Try the Graph editor in Animate. The info is in the Animate PDF.
@Jaderail: I found the Animate 2 user guide here: http://www.gofigure3d.com/site/index.php?option=com_content&view=article&id=92&Itemid=86
Does it also exist in PDF-format? It'd be easier to print.
It can be usefull for obtain pdf from webpage:
http://www.sciweavers.org/free-online-html-to-pdf
I also use a PDF printer, it converts any file to PDF and then I print them out. Some will even let you edit the PDF before you save.
