Loading multiple objects/figures into DAZ using scripts
Hi I wanted to write a script to load an item multiple times and shift into a row or array structure. I have winterbrose script tutorials which tells me most I need to know such as how to move the object once it is alreadly loaded and other general scripting info. However I don't know how to load an object or figure. That is what code line to use and methods and syntax. I also don't know what file I would need to point the function or method at to get it to load the figure.
Any help would be appreciated. I don't know whether the winterbrose gaggles and crows tutorial actually has this info or a script to do so. I could purchase this if it would help.
Regards
Ed
