Convert an Autodesk .max file to fbx help
I have a file freebie, and it's a .max NOT 3ds.  I thought Meshmixer might open it, but guess not. Just confused as to why the Autodesk icon shows for me on my desktop for the file as if I have a 3D programme that will open it. I don't have that PaperPort thingy and I want to work with it not just view it.
Anyone have Autodesk/Maya, whatever... and could convert it for me?  It's only 1mb.
Cheers if you can!  heart  Silene
  • magaremotomagaremoto Posts: 1,238
    this is what I get from max 2017
    dunno if it works for you
    zip
    zip
    max2017.zip
    182K
  • SileneUKSileneUK Posts: 1,977
    edited October 2018
    Oh bugger... I know .max isn't mesh, but what a bummer.  I had several dds files as well and there is only one texture jpg file which is the ground.  Actually, they look like billboard forms! I thought the plants would be vertex models.
    Thank you for giving it a go for me.    It was supposed to be this.
    http://www.cadnav.com/3d-models/model-33537.html
    yes  Silene
    Post edited by SileneUK on
    you're welcome
    you can convert dds files, into tga for example, via xnview
    here is your dds in tga format to be applied within carrara
    zip
    zip
    Modeling_C011756.zip
    2M
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,535
    edited November 2018
    DAZ studio will load dds
    game engines use it with mipmapping
    My Skyrim and Witcher mesh exports all use it
    Irfanview will also convert it and Gimp with a plugin
    Thanks Magaremoto very much...and Wendy!  I will give them a whirl later today... I use tgas a lot with my terrains (I have World Creator). I don't have a problem with billboard vegetation and have a lot of X-Frog stuff. In the distance they can be very useful and not memory hungry. I wanted to only have to model a few detailed plants and this mock quill was one of them.  Will see how it goes if I can use mine, then have a field of these in mid-distance.
    yes  heart  Silene
    Here's a quickie low-res but medium lighted render demonstrating how I used the white quill plants in the tundra so far. They are a good filler. I will use billboards for all of the plants most likely except for the berry plants and the junipers, lichens and moss which will be added later. It's big scene, so will only populate the areas that will be in the renders with detailed stuff.  The caribou (by AM) has Carrara hair, but I left it off to speed up the render.
    Thanks again!  yes  Silene
    640 x 480 - 503K
  • HeadwaxHeadwax Posts: 10,459
    lovely foreground
    Thanks, Andrew, high praise from a very talented artist.  heartkiss  Silene
