Anyone know why this is happening?
gsil247gsil247 Posts: 231
Does anyone know what is going on here with this. The link is what is suppose to show, the render is what is showing. Its just a base genesis 8 male figure with no mods to see if it works or not. Can anyone help me, or does this product not work correctly?
https://www.daz3d.com/cybernetic-head-for-genesis-8-male-s
Post edited by gsil247 on
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,505
    edited October 2018
    you using the correct render engine for the shaders?
    I don't own it BTW
  • Try to use 3Dlight and Iray render mode. See both results, problably will change it. Another option is look at the mod options, you could find something related to the materials applied.
  • I don't have it, but I suspect it's a GeoGraft - make sure the currently active tool is not the Geometry Editor or the Node Weight Paint Brush tool.
  • gsil247gsil247 Posts: 231
    edited October 2018
    I [greatly] love you guys. Thank you so much for your help im all this. I tried all those things at once and it worked. Not sure which one it was, but who cares really, so long as it works. Thank you guys so much. I got so excited, I added it to my piece. I know, his feet are not touching the ground and the lighting is  off. I got so excited, I didn't even bother to fix it.
    Edited for profanity
    1200 x 960 - 2M
