Blank figures
drafter69_696b99e42b
Many products seem to use these blank stick figures to illustrate various poses. Does anyone know what product they are using???? Is it something that Daz sells?
Thankx
Please don't use bars to blank out parts of nude images. In fact at least one of those you posted woudl have been OK, since they weren't skin coloured.
I'm not sure why you say stick figures - those were a standard human with a flat colour material applied, which is pretty easy to do - just set up a material you like (for example using a sphere primitive), make sure you have the model and the surface with the material seelcted, File>Save As>Shader Preset. The select your figure, in the Editor tab of the Surfaces pane click the figure name to select all of its surfaces, and apply the preset you just saved.
Thanks... I called them stick figures because I wasn't sure how to refer to them.... As for nudity with Daz they are unpredictable......
The TOS is very clear on what is unacceptable for posting.
I put the blank areas in for a reason..... and make no apologies.
