Harpwood Trail - Forest Drive does not render.
XanathonXanathon Posts: 88
I bought the new Harpwood Trail - Forest Drive yesterday, but I cannot get it to render. I let the computer run over nicht, but after 10 hours it was still at zero percent.
I can render the other Harpwood sceneries just fine, and my render machine is an i7 with a GTX 1080 TI, so this should work nicely. But it does not.
Any ideas?
Edit: If I cancel the render DAZ Studio crashes.
regards,
Xanathon
Post edited by Xanathon on
  • In Render Settings, what do you have set for Instance Optimisation (assuming you are using Iray)?
  • XanathonXanathon Posts: 88
    edited October 2018
    Yes, I am rendering in iRay.
    Instancing optimisation is set to "Speed".
    Edit: If I set it to "memory" the scene renders. Quite absurd since the video card has 11 Gig of video ram ...
  • Oso3DOso3D Posts: 15,118
    It's pretty much standard procedure to switch to memory for any seriously instanced scene.
  • Yes, Memory does seem to be necessary more often than not with populous scenes
  • TaozTaoz Posts: 10,353
    It's interesting though that there's so much difference between these two setttings. It starts rendering in less than a minute when set to Memory but it takes hours (if it ever starts) when set to Speed.
    edited October 2018
    I never had that issue before - and I was rendering quite complex scenes in the past ...
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,581
    edited October 2018
    it is to me at least ridiculous it is set to speed by default
    I never found it to be any faster even in scenes without instancing
    and surely DAZ can make it revert to memory if a certain amout or any instances present or at least pop up a dialogue box suggesting or enabling it to be if instances present upon clicking render.
    But where they using a lot of instances?  The Instance Optimisation only affects instances.
