Content not loading
Hi,
I've recently switched over from mac to windows and keep getting this error when trying to load anything (see picture).
my OS is stored on a small SSD so all my software an content is stored on a seperate drive, all paths link to where files are stored so I reall don't know what's going wrong.
Tahnks for your help!
  • It looks as if the paths are not, in fact, correct. The exclamation mark in the middle of the frame means thumbnail not found, the one at bottom-left means file not found. Did you copy your content across, or did you install afresh? If afresh, DIM or Connect (or manual)?
