Strange render
This happens to me in a render I tried to change room and create a new one I checked that the cam was not under the ground I checked all the settings of render, but I still have this result. I'd like to know what it's due to, thanks for help
  • Is it the back of a light?
  • No use hdri by Dreamlight
  • MasterstrokeMasterstroke Posts: 2,365
    I cannot garantie, that this will solve your problem, but maybe... Check some materials. are there some for 3dlight? With 4.9, I ran into issues, having IRAY rendering black or crashing in some cases. Recentley, I had the weird issue, that my render only showed the hdri environment and ignored the scene. It is possible, that IRay still makes problems with 3dlight, just differentley, because it has been updated since then. So check materials, convert them to Iray mats, in case you find some and see if that helps.
  • Thanks Masterstroke no material is 3dlight. the strange thing is that it only renders me half a scene as if the dome happens halfway through the room, I have also created a new room but the problem remains.
  • If you move the cam right or left something change or is always half render?
