Can't Start Daz Studio
I installed Daz Studio 4.6, pasted my serial number, clicked "Ok", and nothing happened. None of the buttons or links work. The install manager is the same way too, after signing in. Everything is just unresponsive, yet all the buttons and check boxes still animate. Uninstalling and re-installing didn't help. How do I fix this?
Can you answer the following questions please?
What Operating System are you using? Is it DS4.6 32 bit or 64 bit. What version, public (latest) or Beta? How did you install it, manually or using the DIM?
Does DS4.6 run, and if so, can you see the DS4.6 interface? Can you post a screenshot please?
Woop. Nevermind. I solved it by running DIM as administrator. Everything worked and I installed Daz Studio from there. Should have thought that sooner.......
