mcjTracer2 plugin for DS4.5 + PC-WIN - display animation paths in your scenes
mCasualmCasual Posts: 4,607
edited August 2013 in Freebies
download and instructions ---> https://sites.google.com/site/mcasualsdazscripts2/mcjtracerv2
this is an expanded version of mcjTracer which is still available at
https://sites.google.com/site/mcasualsdazscripts2/mcjtracerds45]mcjTracer plugin
it can display "live" trajectories of animated objects
Figure 2 : same curve after the ball was keyframed at 1 frame intervals using mcjDecimate
Figure 3 wasting time :)
Figure 4 - modulated using mcjCycleFilter
Post edited by mCasual on
  • mCasualmCasual Posts: 4,607
    edited August 2013
    see that? .... 300 blobs ( aka metaballs ) ... the possibilities ( 3Delight renders only )
    figure 2 - a first software render of lines - the plug-in was set to treat the 300 positions of the sphere as if they were a suite of 4-segment lines
    figure 3 - more testing
    600 x 375 - 43K
    1280 x 800 - 100K
    900 x 562 - 45K
    900 x 562 - 63K
    900 x 562 - 57K
    edited August 2013
    that's a 300-segments path rendered as Splines in 3Delight/Software render mode
    1920 x 1200 - 623K
    1920 x 1200 - 976K
    Oh this looks like fun ;-)
    it can be done presently using mcjTracer http://www.daz3d.com/forums/discussion/18888/
    the new thing is that we don't have to export animation paths as objs ( using the mcjTracer script )
    dance video ! https://www.youtube.com/watch?v=qOOj22v3-No
    the animation below was done with the old mcjTracer plugin and the mcjTracer script
    240 x 310 - 682K
    edited August 2013
    a tree displayed in daz using the upcoming mcjTracer plugin for ds4 !
    ( the tree generation code comes from http://techie-notebook.blogspot.ca/ )
    guess i'll add line width control, which was not usable on the previous version of the plugin which could only display object edges
    figure 2 - if the ( newly added ) option Width-control is enabled, the object being trace gets an additional property named LineWidth, which can be used (animated) to modulate the line width of each segment
    figure3 - hardware render - line width control coming along ... it's starting to look a lot like xmas :)
    fig 4 - found a way to make the plugin "lift the pen from the paper" by using a linewidth of 0
    fig 5 - i decided the XScale parameter of the node being traced will be used ( optionally ) to adjust the trace width on a per-frame basis
    ... instead of grafting a new property to that node ... safer that way
    1920 x 1200 - 757K
    1280 x 720 - 466K
    1920 x 1080 - 749K
    1280 x 720 - 70K
    1600 x 900 - 456K
    workin' on it today too
    it's almost ready but yesterday i was getting very strange bugs, so i'm trying to ascertain i fixed them
    ( i think it's related to 'const' and multi threading issues and access to non-const data )
    1920 x 1200 - 294K
    edited August 2013
    well in the end i didn't work much on the tracer plugin, but but, i did have a mcjTracer node in the scene as i was building the WonderAmy ( or WonderAiko ) costume and it didn't have adverse effects
    there's just the hair & headband i'd need to fix
    fig 2 better fit but oops i squeezed the red star
    600 x 800 - 87K
    800 x 1000 - 132K
    1920 x 1080 - 402K
    edited August 2013
    the plugin didn't crash yet !
    so, possibly it's stable and will be published this week
    WonderAmy vs the stickperson
    1920 x 1080 - 249K
    1280 x 800 - 286K
  • RAMWolffRAMWolff Posts: 10,369
    Your always making such neat stuff!
    So not sure what you did to the Wonder Aiko with this plugin. is is the hair?
    Love the idea of building trees!
    edited August 2013
    well there's the rope in one image
    and the sort of line-daisies in another
    and there were 3 mcjTracer nodes in the scene ( not shown ) that did not cause crashes .... which was part of my robustness -tests of the plugin
    now i just want to add one display mode ( per frame instead of per-keyframe )
    and publish it
    then get back to .... oh yes the mcjShrinkWrap project :)
    1280 x 800 - 269K
    1520 x 579 - 892K
    edited August 2013
    close ups showing that by displaying both vertices ( as disks ) and edges ( as elongated rectangles we get contimuous lines without apparent breaks -- in hardware and software renders
    1280 x 800 - 157K
    1289 x 808 - 75K
    using the "per frame" mode you'll be able to quickly visualize the path followed by animated things, in this case a finger
    also quite practical to detect jitters in an animation
    640 x 400 - 580K
    Looks cool. Since I don't do animations this would probably not be very useful for my needs but still looks cool! :-)
  • JaderailJaderail Posts: 0
    I'm So loving your items Casual. I can not wait for them all to be updated to DS4+. I will soon need many to help me do some things I intend to do. I'll manage with what works so far and even cheat and use DS3 for some stuff. Thank you for all your DAZ Studio animation work. I for one notice and wish to take the time to say Thank You.
    welcome/thanks!
    the order should be something like, this one, mcjShrinkWrap, mcjLattice
    and somewhere in there, a kinect/OSCeleton plugin and maybe some Webcam/OpenCV
    also maybe adding a level of undo to mcjWarp .... oh and 3d paintimg or stamping
    edited August 2013
    the history minute ( for people like me who kinda were forgetting this )
    last year in September i posted mcjTransport which lets you create tubes based on paths
    https://sites.google.com/site/mcasualsdazscripts2/mcjtransport
    and we're talking variable diameter tubes like this horn
    so after creating / editing / visualizing your paths with the new (upcoming) mcjTracer, you could convert it to a tube which can be rendered by all renderers
    > > > > > little promo video http://www.youtube.com/watch?v=n7h1nvH8Grc
    1000 x 1000 - 79K
  • SixDsSixDs Posts: 2,384
    I have been following your threads with great interest, Jacques, and I am reminded of the quote from the Joker in the original Batman movie: "Where does he get those wonderful toys?".
    Anyway, I've been playing a bit with some of your plugins and am amazed at what they can do, which is, of course, merely a reflection of what you obviously can do. Or imagine. Thank you so much for the generous gifts of your time, efforts, and skill. I haven't even scratched the surface yet (so little time, so many toys).
    Thank you once again, you make DAZ Studio more fun!
    (Maybe DAZ should hire you.) :)
    welcome, thanks i'm always glad to see that some one uses them :)
    edited August 2013
    apparently it's ready :)
    you may want to subscribe to this thread because i may improve the plugin and post the script which builds trees using the plugin
    first update will be posted this evening : you get variable width control for the Software renders !
    here you see a 100-frames animation curve displayed as a variable-width spline
    figure 3 software-rendered tree test
    1920 x 1080 - 744K
    1180 x 620 - 212K
    1280 x 640 - 67K
    Thank you :-)
    Thank you :-)
    welcome !
    This just in .... the version with variable-line-width in software renders was posted 1 minute ago
    same bat channel
    fluke tree !
    i'm preparing the tree-generator script
    and by accident it generated a tree that seems to be the result of a randomizer bug
    .... meaning branch lengths and bends were supposed to be random and they are not
    1920 x 1080 - 696K
    edited August 2013
    to do probably sunday
    here you see a hardware render of a tree which looks as expected
    each line segment is terminated by setting its width to 0
    but the software render unfortunately shows a shard going from that end point to the start of the next segment
    800 x 450 - 47K
    800 x 450 - 41K
    http://www.daz3d.com/forums/discussion/27811/
    mcjTreeMakerA is a companion script for the mcjTracer2 plugin
    but it can also be used without the plugin to export web-browser-renderable vector art files ( SVG )
    it creates 2D flat tree shapes ( no leaves )
    The recursive tree building method was developped by Gurpreet : http://techie-notebook.blogspot.ca/
    1280 x 720 - 212K
